ciao eccomi qua :
elica : slow fly 10 x 4,7 "
motore :
venditore :
Modellismo WWW.WINNING-MODELS.COM - modellismo dinamico - radio servi motori elicotteri aerei brushless regolatori ESC
motore himodel modello 2815
Specifications:
KV: 1200
Dimensions (mm): Φ28×35 (excluding motor shaft)
Weight (g): 64
Shaft Diameter (mm): Ф3
Battery: 3~4×Li-Poly
No load current (11.1V): 1.1
Max Current (60s):14.2
Max Speed (rpm):9000
Max Thrust (g):670
Recommended prop:APC 10×6,9×5,8×4"
Similar motor: AXI 2212/20
Includes/Requires:
Includes:
1 x motor
1 x motor mount
1 x prop adaptor
3 x banana connector
regolatore :
Himodel
Specification:
Output: Continues 25A, Burst 35 up to 10 Secs.
Voltage Input: 5.6V - 15.0V (Lithium : 2 ? 4S or NiMH/NiCd 5 -12 Cells)
BEC (Battery Elimination Circuit) Output: 2A
Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM. (BLM: BrusheLess Motor)
Size: 24mm*45mm*11mm (width*length*high)
Weight: 24g
servi : microservi se non sbaglio da 8 grammi. ricorda la prolunga a Y per comandarli con un canale solo.
se serve altro chiedi pure buon lavoro!
P.S. IMPORTANTE :
il salvaelica !
