Discussione: Graupner Hott
Vecchio 03 febbraio 12, 00:02   #125 (permalink)  Top
wwww3
L'avatar di wwww3
Data registr.: 04-09-2005
Residenza: Lago d'Iseo
The socket marked “5” - channel 5 - is intended for the optional telemetry sensors and is used for loading
firmware updates in conjunction with the USB interface.
When using the receiver GR-12S (Order No.33505) the adapter cable Order No. 23048 is also needed.
Note: to use the telemetry function of channel 5, select the telemetry menu SETTING AND DATA
VIEW of the transmitter or Smart-Box, go to the Display „RX CURVE“ and “5CH FUNCTION“
and select „SENSOR“ instead of „SERVO“.
With telemetry sensors connected to socket 5, servos
will not longer work at this output! As standard the servo function is enabled on channel 5 - „SERVO“
wwww3 non è collegato   Rispondi citando
