Vecchio 30 gennaio 12, 17:48   #5 (permalink)  Top
S_Ciambra
L'avatar di S_Ciambra
Data registr.: 28-11-2009
Residenza: Palermo
Giuseppe.
l'E-Scorpion va benissimo con la P20, tant'è che la consiglia anche la casa costruttrice...
for 90 mm diameter electric ducted fan
or for 2.5 to 4 kg (5 - 9 lbs.) thrust jet engine
Designed by Eric RANTET
Model E-SCORPION
Span
1.25 m
49’’
Length
1.50 m
59’’
Weight in EDF version
3.2 kg without batteries
4.2 kg with batteries
7.1 lbs without batteries
9.3 lbs with batteries
Fan
1 fan 90 mm, 3 kg (6.6 lbs) to 4 kg (8.8 lbs) thrust
RC lander, Schubeler
Weight in turbine version
4 kg without fuel
8.8 lbs without fuel
Turbine
1 turbine 3 kg (6.6 lbs) to 4 kg (8.8 lbs) thrust
Wren 44, Jet Cat P20
Saluti
Salvatore Ciambra - Palermo (Italy)
__________FAI 11105
S_Ciambra non è collegato   Rispondi citando
