Discussione: Ventola Accucel-6
Vecchio 09 dicembre 11, 16:20   #5 (permalink)  Top
STENO
Guest
Messaggi: n/a
Nico se ne parla in giro.....parecchio direi s egoogly accucell 6 noisy fan trovi un sacco di roba.
Ad ogni modo le + gettonate sono:
1) La ventola non serve: disconnnettila (a me sembra un akazzata...)
2) I opened my case, peeled the tape off the back of the motor, added one drop of oil and had the case back together faster than this guy unplugged his. Now my charger runs super quiet and still has the fan intact.
3)If you want to oil the fan: Remove the 8 screws (4 on each side of the charger) and then you can open the charger case by pulling the top and the bottom away. Then you will see that the fan is connected with a simple 2-pole connector to the board. Unplug it and get some oil into the fan, plug it onto the board again, put both case parts together (watch out for the balancer ports!) and reassemble the screws - youre done.
4) the fans do get noisy, but a quick application of contact cleaner gets the grit out of the fan body and the noise goes away.
In buona sostanza, il mio non scalda a meno che carico due lipo contemporaneamente (come una 6S) oppure quando faccio il discharge pe rcui anche se la ventola smette di funzioanre se ci stai attenot lo puoi usare lo stesso.
Fossi in te cmqe.... lo aprirei e gli darei un'oliatina...
  Rispondi citando
