sono i due nuovi motori rilasciati da os per f3c e 3d
os max 105-hz per f3c
os max 105-hz-r con cline regulator per 3d
Japans OS Engines is jumping in the nitro motor wars with their latest addition the OS 105HZ and 105HZ-R. O.S. E The engines are designed for (F3C) 90-class helis and feature an increased displacement of 17.17cc while retaining 90-size dimensions. Both engines sport a large blue anodized cooling head, large aluminium Venturi for the carburetor and the Max-105HZ-R also O.S. Engines DRS carburetor for a constant fuel supply during demanding 3D flights. Together with the engines the Japanese company will also release a special 3D Power Boost 105 pipe.
