Hello together,
At one of my photos you can see my "helping hand", for the soldering works of the pipe clamps.
This is absolutely necessary to produce some pipe clamps and to solder them.
A very simple construction made of a 3mm aluminum wire, but is very helpful.
The brass tubes was slotted and then I inserted the clamp in the slot and soldered.
All holes through the wing spars, I reinforced with 1mm thick pine strips. So they do not break.
I wish you much fun and a good week.
Greetings Gab
