Vecchio 17 ottobre 11, 11:57   #4 (permalink)  Top
simone76
Guest
Messaggi: n/a
dal manualetto, questo sconosciuto..
http://media.hobbypeople.net/manual/210970.pdf
Crankcase Breather Nipple
A nipple is located on the bottom of the crankcase. This is a breather nipple
and should not be plugged or have any part of the fuel system hooked to it.
Ideally, the nipple should be left as-is; however, a short piece of fuel tubing
can be attached to it and run outside of the cowling or fuselage.
WARNING Do not plug the breather nipple or the engine will not run
properly. If you place an extension on the breather nipple it should not be
more than 3" long.
PS: Magnum, SC, ASP, SY, PH, Sanye,....... stessa mamma, padre incerto.
  Rispondi citando
