Discussione: Problemi Frsky
Vecchio 27 settembre 11, 05:10   #4 (permalink)  Top
MisterX
Rivenditore - My-RC
L'avatar di MisterX
Data registr.: 03-01-2006
Residenza: Canton Ticino
Invia un messaggio via MSN a MisterX
3.3 Receiver and Transmitter Setup Instructions
Follow the steps below to properly set up your system.
a)
Turn your FUTABA OR JR transmitter on and switch it to PPM mode, power off the TX.
b)
Turn the transmitter on while holding the programming button. Release it a few seconds later. The RED LED on the transmitter module will flash indicating the transmitter is ready to bind the receivers.
c)
Connect the battery to the receiver while holding the receiver’s button. The LED on the receiver will flash indicating the binding process is complete. Turn off the receiver.
d)
Turn off the transmitter finish the binding procedure.
e)
Turn on the transmitter. Connect the battery to the receiver when ORANGE/RED LED on TX is on. The LED on the receiver will indicate the receiver is receiving commands from the transmitter. In a few seconds system is ready to work (communication is established).
After the steps above are completed, both the transmitter and receiver are ready to be used. Binding is required only to set up a new link (like new or additi0onal receiver or transmitter module). Otherwise, just go to step e.
To control multi-receivers, every receiver should be programmed with the transmitter in binding state (step b). After all receivers are binded, turn off the transmitter.
Se hai problemi a tradurre fai un fischio....
Carmelo
MisterX non è collegato   Rispondi citando
