Discussione: Rx compatibile futaba
Vecchio 21 settembre 11, 13:44   #2 (permalink)  Top
md30701
L'avatar di md30701
Data registr.: 17-04-2004
Originalmente inviato da tommy88 Visualizza messaggio
uuup! solo Rx compatibili.. non volevo spenderci troppo!
Ciao, ho una compatibile a 8 canale nuova, mai usata completa di seconda scatola come da foto.
Spedita con prioritaria a 27 euro.
Compatible with Futaba FASST receivers: TM7, TM8, TM10, TM14 + more.
The OrangeRx 8ch is only 9.7g in weight and 30x45x10mm in size. Great for small planes, helis, parkflyers or even medium sized sport planes.
Key features.
Light weight 9.7g
Compatible with FASST aircraft radio and module systems
8 Channels
Compact design 30x45x10mm
Twin antenna for diversity and long range.
Input voltage: 4~9.8V
Specified Range: 1.5km+
Resolution: 3072
Latency: 22ms
Failsafe
Included.
OrangeRx Futaba FASST 2.4Ghz Compatible 8Ch receiver
All OrangeRx receivers come with a 12 month warranty.NOTE* This is not a Futaba receiver, nor is it a copy of a Futaba receiver.
Futaba and FASST are trademarks of Futaba Co (JP).
Note* Disable failsafe on transmitter, otherwise you will experience servo jitter.
Ultima modifica di md30701 : 08 ottobre 12 alle ore 07:12
md30701 non รจ collegato   Rispondi citando
