08 settembre 11, 10:48
#427 (permalink)
Top |
| User
Data registr.: 27-08-2010 Residenza: Modena
CIAO RAGAZZACCI!
Grandi Novità!
ho contattato via mail la anderson model e mi son fatto tolgliere qualche dubbio! ho chiesto quali pessi fossero in carbonio e quali fossero solo estetici e l'esito (come immacinavamo) è stato questo:
Carbonio
#M5S9370 - Carbon Main Frame ::: ANDERSON MODEL CO., LTD ::: This is Carbon material in black
#M5S9371 - Carbon Upper Frame ::: ANDERSON MODEL CO., LTD ::: This is carbon material in black
#M5S9372 - Carbon Rear Frame ::: ANDERSON MODEL CO., LTD ::: This is carbon material in black
Carbon-Look
#M5S9373 - Rear Arm (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with Carbon look
#M5S9374 - Front Wheel (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, It is plastic but print with carbon look
#M5S9375 - Rear Wheel (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with Carbon Look
#M5S9376 - Front Shock Body (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with Carbon look
#M5S9377 - Brake Disc (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with carbon look #M5S9378 - Handle with Muffler (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with carbon look
#M5S9396 - Bike Stand (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with carbon look
#M5S9397 - Battery Case (Carbon Texture) ::: ANDERSON MODEL CO., LTD ::: This is not carbon, it is plastic but print with carbon look
Carbon-Silver
#M5S9407 - Carbon Main Frame (Silver) ::: ANDERSON MODEL CO., LTD ::: This is carbon material in black color (qui immagino si sia confuso e intendesse silver)
#M5S9408 - Carbon Upper Frame (Silver) ::: ANDERSON MODEL CO., LTD ::: This is carbon material in silver color
#M5S9409 - Carbon Rear Frame (Silver) ::: ANDERSON MODEL CO., LTD ::: This is carbon material in silver color la seconda domanda è stata:
-is the black carbon fibre more resistant than the silver carbon fibre? They are about the same durable, just some people like black color, some people like silver color. e in fine l'ultima domanda:
what is this part? and how does it work?
#521602 - Receiver Noise Capacitor ::: ANDERSON MODEL CO., LTD ::: This is a capacitor to plug into the ESC if you use the motor which has higher KV more than 4900kv, then plug this capacity is better,If your motor KV is under 4900kv, it is no need to use this capacitor. |
