Vecchio 24 agosto 11, 21:10   #5 (permalink)  Top
rugrug
L'avatar di rugrug
Data registr.: 08-03-2010
Originalmente inviato da giochi64 Visualizza messaggio
Scusate le domande da autentico principiante: cosa significa avcs e come mai quando imposto la percentuale oltre il 50% lo stick del rotore di coda, quando lo porto lentamente dall'estremità al centro, non comanda più il servo che non torna più in posizione centrale?
Angular
Vector
Control
System
è la funzione c.d. Blocco di Coda o Head Holding o Heading Hold...
appunto che oltre il 50% passi dalla modalità "normal" o "rate" a quella AVCS, che tende a compensare le variazioni di vento relativo sulla coda e riportarla nella posizione iniziale
Futaba® Gyros Frequently Asked Questions (FAQ)
Basics of AVCS/heading hold gyros
AVCS is an advanced version of heading hold which doesn't have the temp related drift problems of most of the older HH gyros.
Heading hold and AVCS mean that the gyro is acting almost like it has GPS to hold it onto its direction. If something other than a rudder input moves the heli off hte desired positioning, the gyro reads how many degrees it has been moved and will continue to give input until it gets back to that heading or until you move the rudder stick to tell it to do something else.
Compare that to normal mode, or a non-HH gyro....in those cases, if something moves the heli, lets say 2 seconds to the left, then the gyro will give input for 2 seconds back to the right. It has no idea if the heli actually mvoed back in place or not, it just tries to soften the undesired movement and goes on with its day.
Now, to give you real world examples...
Your heli is sitting on the ground. You pick up the tail and rotate it 180 degrees. In normal mode, the gyro would give some rudder briefly, figure it did enough, and stops giving input, probably long before you go to take off. In heading hold mode, the gyro says "I am off course by 180 degrees!" and it will give full rudder input until that heli comes around those 180 degrees—thus doing half a pirouette the minute you break ground. This is why you need to be careful with a heading hold gyro on the ground.
PIRO RATE: the rate at which the heli pirouettes when using a gyro depends upon your ATV settings for your rudder servo. The higher the ATV the faster the heli will pirouette as the gyro is giving maximum command to try to get to that commanded position.
GYRO REVERSE: If the gyro is commanding the model in the wrong direction—ie you move tail right and it gives even more right—simply reverse the gyro direction on the unit in this screen.
GAIN at the GYRO? GAIN at the radio? If you leave the gain at the gyro set to 100%, then you can adjust the end points of the gyro sensitivity channel at the radio and they will be linear. That is to say, they will be the same size steps as if you changed the gain at the gyro itself. If you set the gyro gain on the gyro to 50%, then each 1% change at the radio would have twice the effect (since there is half as much room to adjust) as if 1% change was made at the gyro.
DELAY: affects how rapidly the gyro responds when input is given, and when the stick is returned to neutral. If the delay is too low on return and you have a slow servo, it will think the servo should have been there already and give more input, then overshoot, then give more input to correct, and so on, causing a wag. Faster servos can handle smaller and smaller delays.
GAIN TRACKING: used when the gyro overshoots to one direction but not the other, creating a 'hunting' sensation only in one direction.
MODE - NOR, AVC, CMT. Decides if the gyro can be switched in and out of normal and AVCS in flight or if it is set to only one or the other. CMT is combined and allows use of both.
FRAME RATE: HIGH or fast frame rate is in place just for digital servos and must not be used with standard servos as they can not handle the commands at that rate and it will burn out the servo.
LIMIT: This setting tells the gyro how far it can move the rudder servo. REMEMBER do NOT use rudder ATV to adjust the rudder servo total travel, use the LMT function on the gyro.
RUDDER CONTROL GAIN (NCGA): this adjustment affects how responsive the rudder feels in AVCS mode. Adjust this to match how your rudder feels in normal mode so you do not have an unexpected 'expo' response at the rudder from the AVCS mode.
bonne ètude
