Discussione: ahio... altri CC....
Vecchio 21 agosto 11, 01:45   #1 (permalink)  Top
ilbrunge3D
Data registr.: 03-08-2009
Residenza: Pistoia
vi giro una mail arrivata 20 minuti fa...
ICE HV, Mamba XL & Hydra Ice HV
Warning & Recall advisory 2011-03
Aug 20, 2011
The performance of a component used in the Castle ICE HV 60, ICE HV 80, ICE HV 120, ICE HV 160, Mamba XL and HYDRA ICE HV controllers has changed from the original specifications for that part. This tolerance change may lead to failure of the affected controllers.
For your safety, we request that all customers cease operation of these controllers immediately. Send all of these controllers back to Castle for modifications required to improve the safety and reliability of these products. This recall includes all controllers labeled as V3. There are no charges associated with this modification.
The only controllers that are properly modified and are approved for operation will be labeled clearly as ICE HV (Amp Rating) 2, Mamba XL 2 & HYDRA ICE HV 2.
We understand that you may not wish to return your controller. Those that have served you well are likely to continue doing so; however, controllers that you may have recently purchased should be assumed to be assembled with the problem components.
If you insist on using these controllers, please be advised that the risks of continued usage begin with severe burns to you and/or others, as well as property damage to your RC vehicle or surroundings. Please wear fire-proof gloves when connecting any HV controllers that use 8 or 10 gauge wire to their power source.
REPLACEMENT PROCEDURE
Click this link and follow the directions of advisory 2011 - 03 to process your return if you have any of the following controllers.
Phoenix ICE HV 60
Phoenix ICE HV 160 & ICE HV 160 LITE
Phoenix ICE HV 80
Mamba XL
Phoenix ICE HV 120
Hydra ICE HV
North American and all non-European customers:
Please return controllers to Castle in Kansas via a traceable delivery service:
CASTLE CREATIONS, INC
120HV SERVICE / Service Department
540 N.ROGERS RD.
OLATHE, KS 66062
European customers:
Please return controllers via a traceable delivery service to our new European repair center:
CASTLE CREATIONS EUROPE BVBA
120HV SERVICE
GEELSEWEG 80
2250 OLEN
BELGIUM
Note: The Olen office cannot support technical support or warranty calls at this time. Direct all questions to Castle using the normal tech support or warranty service addresses.
Hobby dealers and commercial customers worldwide:
Please contact Lori at Castle in Kansas to make arrangements for return of your stock.
Please be sure to include a copy of the return confirmation generated by the web site in your package.
We sincerely appreciate your patience in this matter. As hobbyists ourselves, we understand your disappointment at not being able to use your controller during this period.
Thank you,
Team Castle
FAQs
1. It may not be possible to economically repair some controllers. Those controllers will be replaced by refurbished controllers that were made from unsold controllers that have been recalled from the sales channels.
2. We will replace the control board in as many returned units as possible. We will make sure that you receive your exact controller. This will likely cause the process to take a bit longer, but it will ensure that you are comfortable with the prior use of the controller that you receive from us.
3. As we cannot state in advance the criteria for reparability vs. replacement, please remove all connectors from your controllers before sending them in to us.
4. Due to the manner in which most of the ICE HV controllers and their heat sinks are assembled, we do not recommend that users ask to install the replacement board themselves.
5. We cannot give you an exact estimate of the time required to return your controllers. We will keep you updated as to the status of our repairs via email. We understand that you may be frustrated by this experience, and we will be happy to talk with you individually, but our Tech Support staff do not have any more information to offer you beyond the statements made in this announcement.
ilbrunge3D non รจ collegato   Rispondi citando
