Discussione: Spektrum Dx8
Vecchio 30 luglio 11, 09:06   #2131 (permalink)  Top
rillo75
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
...c'erto che ce nè di gente che la notte dorme poco
In ogni caso, eccovi le modifiche introdotte:
DX8 Spektrum™ AirWare™
Change Log
Version 2.03
Software Features
• Changed Monitor screen to improve perceptibility of changes in stick and trim resolution.
• Added new wing type Elevon B. This mode is used if control horn or servo positions don’t allow correct throw directions. Eliminates need to swap elevator and aileron servo leads. Also required with some trainer systems like the DX6i.
• When editing the timer configuration, any changes will cause the timer to be reset.
• After reversing the throttle channel, the screen changes to show a reminder to rebind at low throttle for safety.
• To improve the ease of adjusting travel limits for complex servo functions (swash, V-tail, etc), the Servo Setup screens now are tracking servo outputs directly.
• To avoid confusion when binding, we changed the Bind screen to show actual 11ms/22ms bind info instead of what the receiver is capable of doing.
• Enabled adjustment of the telemetry receiver voltage display bar. Adjusting the low and high setpoints (high is NOT an alarm) you are adjusting the scaling of the bar graph for Rx Voltage.
• When importing a model, a confirmation screen now appears to warn about possibility over-writing the wrong model.
• Changed telemetry menu and capabilities to enable access to future sensors.
• Users are now able to calibrate the knob and both stick in both axes. This is done by selecting NEXT several times from the System Setup menu. Move the sticks in a “+” format, NOT in an X or O. It is important not to push the sticks to the corners.
Software Corrections
• Flap/Elevator Smoothness – Elevator compensation travel was not smooth when there was significant trim on the elevator channel.
• Flap Overdrive – Initial flap movement could sometimes cause flaps to jump to one extreme of travel before moving to correct setting.
• Telemetry - Changed scaling for telemetry alarms Altitude & Airspeed. Fixed ‘hidden status’ screens when using models created in older versions.
• Translations – Improve/Correct translation of some terms for German, Spanish and Italian modes, particularly on the Timer and Telemetry screens.
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
Ultima modifica di rillo75 : 30 luglio 11 alle ore 09:15
rillo75 non è collegato   Rispondi citando
