Vecchio 27 luglio 11, 09:56   #1 (permalink)  Top
UAV drone
L'avatar di UAV drone
Data registr.: 17-02-2010
Residenza: su Real Flight
Banner HK comparso oggi
http://www.baronerosso.it/forum/newt...newthread&f=46
commenti degli utenti:
Turnigy Smart6 Balance Charger Review
"Toumal" Well Just got the charger today and almost burned down my House!! This is my 4th charger I have had. So I am not new to chargers. I got if for some of the options. It blistered the pack and I found it just in time and ran it out side. It exploded into flames in 2 min from throwing it out side. It over charged the battery! It was a 6s 2650mah. The charger was blistering hot! I will be sending pic on the blog! I was only charging it at 1c. Always stay by your charger and check it often !!!!
"Anderson" I've used this charger 4 times at 2.8A for 4S Battery and it burned!!! I don't reccomend it, I'm using a cheap IBMAX 6 charger for ~ 1 1/2 years with no issues!
"tououne06" mine stopped working after less than a month! it lights up and when I run the load it beep and says "pow er" I look in the manual and it says that and has a supply mauvaisepower! yet it works very well on the power supply. I try different power supply and it works fine before and the same problem and the loader stops loading and still shows "pow er" beep and I'll have to return him to repair !
UAV drone non รจ collegato   Rispondi citando
