Discussione: aurora 9
Vecchio 25 luglio 11, 17:31   #11 (permalink)  Top
Aeroplanino di carta
L'avatar di Aeroplanino di carta
Data registr.: 23-08-2006
Residenza: Castelli Romani
V1.08(1) online 11Jul11 - contains the following amendments:
1. Spelling changes as lower or upper case letter
. System and Model
MODE - Mode
. Stick Mode – MODE 1 : Mode 1 (2,3 and 4)
[Flight Cond]NORMAL : [Flight COND]Normal
NORMAL - Normal
INSERT - Insert
Cond - COND
SET - Set
Thro. - THRO.
[Throttle Curve] : NORMAL - Normal
Info - INFO
NULL - Null
NONE - None
CAMBMIX - CAMB.Mix
Thro.Cut - THRO.Cut
ThroLock - THROLock
- Spectra Pro
Modulat - MODU
Freq Sel - FREQ.SEL
- Timer
DOWN - Down
UP - Up
2. In the V-tail mix, under Butterfly function, Rudder channel is not working in the V1.08(0), in that (+) and (-) mixing value cannot be adjusted, this bug fixed.
3. Spoiler Channel Control with Throttle stick (Mode 1 - J2, Mode 2 - J3), between the direction of Throttle stick and direction Elevator movement are opposite each other under V1.08(0) is fixed.
Ma vale la pena aggiornare per queste piccole correzioni? Mah...
Aeroplanino di carta non è collegato   Rispondi citando
