Vecchio 20 giugno 11, 23:24   #4 (permalink)  Top
laser02
Data registr.: 16-06-2009
Residenza: Milano
Trovato questo:
Sanwa Mode 1 to 2 change via service mode
1. Switch the radio off.
2. Shift the left switch forward.
3. Hold down F.Mode and End.
4. Switch the radio on.
5. Flip back the left switch.
6. Scroll down to MOD.
7. Select mode 2.
8. Press End.
9. Switch the radio off.
10. Switch the radio back on.
1. unscrew aerial
2. remove all screws from the back
3. carefully lift the back off BE VERY CAREFUL AS THE TRAINER SOCKET WIRES
ARE SHORT AND SNAP EASILY
4. remove the spring / tensioner and seesaw assy from the elevator stick
5. remove the throttle ratchet asembly and stick travel limiters
6. refit to opposite sticks without the limiters
Re asemble the tx
1. With the radio off.
2. Shift all switches forwards / down .
5. Wait for a beep
6. Flip back the top left switch.
7. Release F.Mode and End.
8. Scroll down to MOD.
9. Select mode 2.
10. Press End.
11. Switch the radio off.
12. Switch the radio back on
Other functions of SVC menus
Init-->YES (press yes button)
CH---->yes button selects 6 or 8
NEU--->sets neutral stick positions
TRV--->sets stick calibration
A/D--->VR1....VR6 stick pot values
MODE-->mode 1 or 2(stick orientations) LCD--->All led's lit, some, some, none
SW---->press 'yes' to see switch positions
B*AL-->use +- to set batt voltage alarm
PULSE->Nor, LO, HI
V*Cal->'+' set voltage to 10.0 volts
All-CR>All clear
link:
Help for Sanwa/Airtronics RD8000
Saluti
laser02 non รจ collegato   Rispondi citando
