Vecchio 18 giugno 11, 09:49   #11 (permalink)  Top
cbrseicento
L'avatar di cbrseicento
Data registr.: 29-01-2007
Residenza: latina
@Lift mi ha risposto aoerc.cn dicendomi questo...
gli ho mandato un e-mail per il motore che avevi mezionato tu
AeoRC ADH50 (C05 New Improved Version) Outrunner Brushless Motor
The shaft in 1mm diameter because this can have stocked Walkera pinions used on it. 4#3B is 1mm dismater.
ADH50 (C05) is new improved version. It is lighter and smaller.
Shaft (Diameter): 1mm (Stock Pinion Can be Used)
Mounting Screws are included.
Thrust: 90g
KV: 11300
Aeorc.cn mi ha detto:
Hi,sir
Our AEO ADH50 motor now is called "C05M',you can buy on our website:C05M - Motor Aero Electronics Operations - AEO Tech
in un altra e-mail mi ha detto questo
Sorry,the shaft diameter is 1.5mm,not 1mm.And the thrust up to 80g
You can check the website link:C05M - Motor Aero Electronics Operations - AEO Tech are test data for reference
Mi domando tu non hai preso quello con l'albero da 1 mm? ADH 50
T-REX 600N LE FLYBARLESS-MOTORE-OS 55 HZ MAX LIMITED EDITION-3 SERVI FUTABA 9255-1 SERVO GAS FUTABA 9254-MICROBEASTX-SERVO DI CODA FUTABA 9254-GV-1 PALE SAB PALINI SAB RADIO FUTABA T10 2.4 Gz T-REX 500 - T-REX 450 PRO V3- T-REX 550E-MCPX
cbrseicento non รจ collegato   Rispondi citando
