Discussione: regolatori cc
Vecchio 16 maggio 11, 23:33   #9 (permalink)  Top
dex1
L'avatar di dex1
Data registr.: 19-01-2005
Residenza: 33170 e dintorni
Originalmente inviato da LEVIX Visualizza messaggio
Ciao a tutti, io sul C.C.120, non sono riuscito ad impostare l'end point del massimo poichè il 110% di escursione della mia radio (FC 28) non è bastato, comunque l'ho provato è funzione bene, volevo chedervi se è normale che lampeggi la luce arancione?
Saluti -
se sei in governor,a giri raggiunti,lui lampeggia veloce"led rosso".
se hai la serie ice il led giallo indica che sta registrando i dati di volo,
e se diventa fisso dovrebbe essere memoria piena.
ad agni modo sulle istruzioni ce' una tabellina con indicato
cosa vuol dire i lampeggi+bip.
Error Codes:
The following error codes are only applicable to controllers
running version 1.55 or made after December 15, 2006. The
controller will alert you to errors by blinking the LED and
beeping the motor. Please count the error code beeps or
flashes and use the following chart to determine the issue.
1 beep and flash Start failure: The motor was jammed or
locked.
2 beeps and flashes Low Voltage Cutoff: Your batteries are
likely discharged. Check that batteries
are fully charged and that Phoenix
detects the proper number of cells at
power-up.
3 beeps and flashes Over-Current: Current draw exceeded
the safe capacity of the controller.
Reduce current draw by changing
to a smaller propeller, different gear
combination, or fewer cells.
4 beeps and flashes Motor Anomaly: Controller encountered
abnormal motor behavior such as a prop
strike or other physical interference.
May also indicate lost synchronization or
magnetic overload within the motor.
5 beeps and flashes Radio Signal: Signal from receiver
is corrupt or non-existent. Check
transmitter and receiver.
6 beeps and flashes Over temperature
Beep Codes/Conditions
All Castle ESCs will sound a single beep every 20 seconds to
remind the user that the controller is connected to a battery
and drawing power. Leaving a controller connected to a
battery for extended periods will likely damage the battery.
Red LED
Blinks out c • ell-counts /error codes
• Flashes a little at low throttle
• Flashes a lot at high throttle
• Solid on at full-throttle
• Pulses quickly when governor-mode is locked
Yellow LED - used for Data Logging (Phoenix Ice, Phoenix Ice Lite
and Phoenix Ice HV only)
• Yellow LED flashes when logging, and is on continuously
when log is full.
Green LED - not currently used - reserved
Trattiamo bene la terra su cui viviamo: essa non ci è stata donata dai nostri padri, ma ci è stata prestata dai nostri figli
dex1 non è collegato   Rispondi citando
