Ciao BINA, queste sono le caratteristiche tecniche di questa batteria:
Technical specifications
Nominal capacity and voltage 5200 mAh, 13.2 V
Recommended standard charge method 7A to 14.4 CCCV, 45 min
Recommended fast charge current 20A to 14.4 CCCV, 15 min
Maximum continuous discharge 100A
Pulse discharge 300A
Recommended charge and cut-off V at 25°C 14.4V to 8V
Recommended charge and cut-off V below 0°C 15.2V to 2V
Operating temperature range -22°F to +140°F / -30°C to +60°C
Storage temperature range -58°F to +140°F / -50°C to +60°C
Battery weight 1.98 lb / 900 grams
ma settare il CB per una classica LiFe non dovrebbe bastare? tu che parametri hai dato?
