Vecchio 11 marzo 11, 20:42   #3 (permalink)  Top
giava76
L'avatar di giava76
Data registr.: 24-09-2007
Residenza: Padulle
Se parti col gas al massimo entri in programmazione dopo qualche secondo, verifica sul sito Hacker nella sezione download come fare a riprogrammare il tuo esc o eventualmente verifica se possibile compera il cavetto per il PC, è comodo.
Comunque strano che tremi il motore, in genere non è un bel segno, verifica anche i collegamenti motore regolatore.
Ti allego alcune parti delle istruzioni del regolatore MAS70-3P:
Using the Controller:
Switch on the transmitter and check the throttle channel settings are +/-100% (for
computer radios). For Futaba Radios program the “Servo Reverse” function on the
throttle channel.
Set the throttle to “closed” or brake position
Switch on the speed controller. For speed controllers without BEC, switch on the
power to receiver (just connect the power pack for the Jes 06-3P speed controller).
You must hear a ‘beep’. Between switching on the switch and the ‘beep’ the
throttle stick must not be moved
. If you do not hear a ‘beep’, switch off the
switch, disconnect the power connectors, wait for 5 seconds and repeat the procedure
of connecting and switching on. If you do not hear ‘beep’ again, check the
following:
Is JR connector plugged in throttle channel?
Is the throttle stick in “closed” position (OFF)?
Is the throttle channel in ‘normal’ position? (for Futaba, in the
Reverse position?)
You will hear the ‘beep’ during the first switch-on of the controller only. When you
switch-off the speed controller without disconnecting the motor battery pack, you
will not hear the beep after next switch-on.
 The position of ‘full throttle’ will be adjusted automatically
Setting the Propellor Brake On or Off
The speed controller is supplied with the ‘brake’ ON. If you want to turn off the
brake, do the following:
Switch on the transmitter and move the stick to ‘full throttle’.
Connect the motor battery pack and turn on the receiver switch (if used).
Wait 5 seconds, your will hear a single ( brake on) or a double tone (Brake Off),
Move the throttle stick immediately to the ‘closed’ position.
The brake setting is now memorized, that means it will not change after disconnecting
the motor battery pack. When turning “On” the speed controller with the brake
‘active’, you will always hear one ‘beep’. When the brake is turned off you will hear
a double ‘beep’.
If you want to change the brake function again, disconecting the motor battery
pack. Repeat the procedure.
.l'importante è divertirsi.
giava76 non è collegato   Rispondi citando
