Vecchio 03 marzo 11, 11:18   #549 (permalink)  Top
liftbag
L'avatar di liftbag
Data registr.: 10-03-2010
Originalmente inviato da edubu Visualizza messaggio
Caspita ,complimenti,sei un " cane da tartufi" .. Riesci a scovarli tutti ! ....Con i primi veri video iniziano le risate: tutti quelli che pensano di ritrovarsi un modellino facile facile" da mettere sottosopra non riusciranno ( in una stanza/ salotto) a metterlo nemmeno in hovering di muso .. scommettiamo??!Il grado di " difficolta'" di questo modellino sara' di poco inferiore a quello di un rex 250
Vedremo, io continuo a pensare che sarà più facile da usare di un rex 250.
In Australia è stato consegnato ai primi utenti.
Qui di seguito il primo commento di un utilizzatore australiano.
Got mine at work today and already flown it.
So far I can say it is very stable, you can hover hands off for a few seconds. I would say as stable as the mSR but it will not auto hover like the mSR. By that I mean if you give left cyclic and leave it the heli will carry on flying sidewards like any CP chopper. It wont swing back into a hover like the msr does.
Also the blades are a lot heavier than the mSR - and I can tell already from experience that they hurt a lot more. I tried to hover onto my hand like I do with the mSR and it hit my hand. Doesn't break the skin but it will give a small blood blister. So I expect it can and will break things in the living room.
After "thie incident" the link from the swash to the blade grips fell off. I suggest after any crash to make sure you look for this before leaving the crash site. These are small and will get lost easily.
Also after this incident I found it suddenly had a lot of negative pitch and very little positive. I traced this back to the main shaft slipping upwards on the main gear which is all that holds the shaft down. Once this happens there is some play in the shaft which will reduce your positive pitch when upright and negative when inverted. Again another thing to keep an eye out for.
All in all I am happy with this little thing based on the flight in the office. All I can say now is "HOBBYKING START TO SUPPLY BATTERIES FOR THIS SUCKER!"
A quanto pare c'è da stare attenti agli oggetti di casa ed anche a se stessi, perché le pale sono molto più pesanti di quelle dell'mSR e girano forte.
Link di ricambio sembrano d'obbligo perché pare saltino facilmente e si perdono altrettanto facilmente.
Sulla questione pitch negativo verso positivo, aspetto di averlo tra le mani
liftbag non è collegato   Rispondi citando
