Discussione: Info Xerun 5.5T
Vecchio 25 febbraio 11, 21:01   #4 (permalink)  Top
debug
L'avatar di debug
Data registr.: 13-12-2009
Residenza: Milano
Per caso sono queste le caratteristiche che cerchi? XERUN 6000KV 5.5T RC Sensored Motor & 120A ESC ME254
Motor Specification
Model: XERUN 5.5T Sensored Brushless Motor
Motor Dimension (Dismeter x Length): 35.8mm x 52.7mm
Shaft Dimension: (Diameter x Length): 3.14mm x 13.2mm
Rotation Speed: 6000KV
ESC Specification
Model: XERUN-120A-V2
Dimension: 43mm(L) x 36mm(W) x 33mm(H)
Cont. / Burst Current: 120A / 760A
Resistance: 0.0003 ohm
Suitable Motor: Sensored and sensorless brushless motors
=>3.5T (on-road), =>5.5T(off-road) (Works with 5-6 NiMH or 2S Li-Po),
=>5.5T (on-road), =>8.5T(off-road) (Works with 8-9 NiMH or 3S Li-Po),
Battery: 4-9 cells NiMH or 2-3 cells Li-Po
BEC Output: 5.75V/3A Built-in BEC
Cooling Fan Working Voltage:
5V / 0.16A, max. 8V (The fan gets the power supply directly from the battery)
Suitable Model: 1/10, 1/12 on-road and off -road, 1/8, 1/10 scale rock crawler
ESC Features
Compatible with all sensorless brushless motors and most of sensored brushless motors such as LRP, SpeedPassion, Novak, Etc.
debug non รจ collegato   Rispondi citando
