Discussione: Nano Jets by Robbe
Vecchio 16 febbraio 11, 14:54   #692 (permalink)  Top
Skud85
L'avatar di Skud85
Data registr.: 19-04-2008
Residenza: pescara
infatti, leggo dal manuale che scarico qui:
http://www.spektrumrc.com/ProdInfo/F...anual_DX6i.pdf
Rotate the roller to highlight WINGTAILMIX then press the roller to access the Wing tail mix function.
Reduce photo to 13.5%
SETUP LIST
THRO CUT
WINGTAILMIX 6
D/R COMBI
Main
To Select a Wing /Tai l Type
Rotate the roller to highlight the desired wing or tail type then press the roller to highlight the desired function.
Rotate the roller to inhibit (INH) or activate (ACT) the function.
WINGTAILMIX
DUALAILE INH
V-TAIL INH
ELEVON INH
List
Note: When Flaperon or Delta Wing type is selected, the travel adjustment is used to adjust the
individual servo throw, while the combined aileron travel is adjusted with the aileron dual rate. It
is also possible to set aileron differential. Reverse switches are applicable for each servo. Neutral
adjustments of each servo are made by the Sub Trim Function.
banale, no?
eddaiii scritto così sembra veramente complicato, ma ci si mette 30 secondi... io ho la dx7, ma ho visto coderzone che l'ha messo sulla sua dx6i in un attimo..
On Facebook Quadricottero News
Guida per MicroQuad da FPV
Skud85 non è collegato   Rispondi citando
