Vecchio 24 gennaio 11, 21:03   #7 (permalink)  Top
AMoNgt
L'avatar di AMoNgt
Data registr.: 02-03-2006
io ho visto questo dal vivo
è spettacolare
http://www.modellismobucarelli.it/in...emart&Itemid=1
Hobao Hyper 10 SC RTR NITRO
Technical Data Length: 21 in/533 mm Width: 11 in/279 mm Weight: 5.7 lb/2585 g Wheel Base: 12.75 in/324 mm
Features
SG .18 Hyper Engine Installed 2.4GHz Radio 25cc Fuel Tank Front Steel CVA's 2 Stage Air Filter 3 Shoes Clutch Polished Tuned Pipe Sealed Radio Box Full Set of Sealed Ball Bearings Three Sealed Oil Filled Defferentials Machined Steel Bevel Gears Steel Main Spur Gear Hard Anodized Aluminum Chassis Painted Lexan Body Heavy Duty Servo Mounts Molded Battery Holder Molded ESC Holder Adjustable Battery Strap Front & Rear Sway Bars Aluminum Threaded Shock Bodies And Much, Much, More...
AMoNgt non è collegato   Rispondi citando
