Discussione: orangerx-clone futaba
Vecchio 22 gennaio 11, 13:52   #488 (permalink)  Top
LONGFLYER
L'avatar di LONGFLYER
Data registr.: 06-09-2008
Smile
Originalmente inviato da ninja75 Visualizza messaggio
non credo che tutti i servi solo perche' sono digitali possono essere configurati in hs mode, qualcuno ne sa di piu'?
Futaba spiega ... Futaba 2.4GHz FASST Receivers ... che:
# High-speed operation takes advantage of digital servos’ ability to update more rapidly than analog servos (both can be used with this receiver)
# HS (High Speed) mode improves frame rate on channels 1-6 to only 7 milliseconds — compared to 14 milliseconds at normal mode.*
* Note: In HS mode, digital servos (including those in the BLS series) must be used on channels 1-6. Those channels will also operate gyros and brushless ESCs. Channels 7 and 8 continue at normal mode and accept any servos.
"If flying were the language of man,
soaring would be its poetry."
Ultima modifica di LONGFLYER : 22 gennaio 11 alle ore 13:56
LONGFLYER non è collegato   Rispondi citando
