Discussione: Spektrum Dx8
Vecchio 29 ottobre 10, 23:45   #9 (permalink)  Top
liftbag
L'avatar di liftbag
Data registr.: 10-03-2010
Firmware 1.04
E' stato rilasciato.
Questo il changelog:
Version 1.04
Software Upgrades
• Trim Center Pause – When adjusting the trims through center, the pause was
lengthened to allow the center position to be more easily accessed.
• Knob Center Tone – When adjusting the knob, it generates a “center trim” tone as it
rotates through center.
• LiPo Battery Verification – Attempting to change the battery type in the Extra Settings
screen from NiMH to LiPo will not be allowed until a LiPo battery is installed. This
prevents the user from mistakenly selecting the LiPo battery voltage cutoff with a NiMh
battery installed.
• Frame Rate Defaults to 22ms- The Frame Rate now defaults to 22ms rather than
11ms. This prevents analog servo compatibility issues in the default mode.
• AirWare Auto-Update – To guard against inadvertently downgrading the radio’s
AirWare, after installing version 1.04 or higher the system will rename the update file to
prevent it from auto-loading in the future.
• Startup Screen – The startup is changed so that no inaccurate “No RF Link” warning is
displayed.
Software Corrections
• Heli Mode Trainer Button – if the Trainer button was assigned to a channel in the
Switch Select screen, the channel was inactive.
• Flap Trim – When a Flaperon wing type was selected and the right or left trimmer was
assigned to flap trim, the trim was mixed as ailerons instead of flaps. It was also not
possible to deactivate flap trim once selected.
• Acro Throttle Curve – Pressing the CLEAR button could allow the displayed throttle
curve to not match the values entered numerically.
• German Timer – The prompts for the German-mode throttle-based timer controls were
renamed so as to be more intuitive.
Throttle = Gasstellung
Throttle 1-time = Motorstart
Throttle Out = Motorlaufzeit
liftbag non è collegato   Rispondi citando
