Vecchio 03 settembre 10, 22:31   #8 (permalink)  Top
braniac
L'avatar di braniac
Data registr.: 08-10-2005
Residenza: (FR)
Invia un messaggio via MSN a braniac
Originalmente inviato da rugrug Visualizza messaggio
la buttò là...
tensione cinghia?
in forum Usa si lègge che i trex richiedono tensioni precise...
belt tension on a trex is a art in itself. to tight they wear out fast and cut flight times down and your heli wont auto well to loose and they slip and you loose tail authority..
when i adjust tension i have the main blades off and i start a hair on the tight side, i spin the head and loosen the belt and you can feel when the head and belt starts to spin freely with no drag i stop there, anymore and the belt will slip
theres no time to learn like rite now as when you wreck your going to have to tear into it anyway.
ok, proverò ad accorciare leggermente il tubo allentando la cinghia, grazie del suggerimento, di palini ho montato quelli più grandi
PhoenixLaser-FanCub-F86Sabre-FlitonMiniExtra260-PAElectricShock-4Site-Corsair-
UMXPolecat-Mig15-HiroboShuttle-Trex500-Trex250-230S-V931
-Pitts 1s-Rifle 1m-Blade230S-Umx Longitude-Umx f-16-Umx Gee Bee-Blade Mcpx BL2-Thunder tiger MD500
braniac non è collegato   Rispondi citando
