Vecchio 08 aprile 06, 11:24   #4 (permalink)  Top
Teo678
Guest
Messaggi: n/a
Originalmente inviato da DUKAFLY
- Switch on the transmitter and move the stick to full throttle.
- Connect the main power pack and turn on the receiver switch (if used).
- Wait 5 seconds.
- After 5 seconds you will hear 4 tones.
- Move the throttle stick fast to the closed position, you will hear two beeps.
- The brake is now turned off.
The brake setting is memorized, that means it will not change after disconnecting the main power pack. When turning on the speed controller with the brake active, you will always hear one beep. When the brake is turned off you will hear a double beep. If you want to activate the brake again, repeat the procedure.
"non basta a ringraziare" !!
mi hai risolto il problema
teo678
  Rispondi citando
