Originalmente inviato da fabionet31 grazie sandro ma non mettenono max 22V ?? |
No perché?
ecco i dati dal sito het:
-Diameter : 36 mm/1.42 inch
-Length : 85 mm
-Shaft Dia. : 5 mm
-Rotor length: 45 mm
-Weight : 290 grams
-Poles : 6
-Internal resistance: 23
-No load current(lo) : 1.6
-No load KV : 1400
-Max Current: 70 A
-Max efficiency: 85%
-Power Nominal: 1500 Watts on 8S
-Recommended for
7 lipo cells on Wemotec Midi fan and 8 lipo cells on HET 9305 fan unit
