Vecchio 15 giugno 10, 10:48   #4 (permalink)  Top
rc-modelmania.com
Rivenditore-RC-Modelmania
L'avatar di rc-modelmania.com
Data registr.: 12-05-2008
abbiamo avuto modo di fare diverse prove qui in zona su quel modello.
il miglior risultato è stato ottenuto usando
questa ventola
Delta-V 15 69mm EDF by E-flite cod. EFLDF15 prezzo a pubblico €. 25,00 circa
Delta-V 15 69mm EDF Features:
• High-performance, efficient design with
• Quick assembly time
• Injection molded, high strength fiberglass-filled Polyphenylene Sulfide [PPS] plastic
• Factory-balanced 69mm 5-blade rotor design and aluminum spinner
• Includes center body fairing to reduce drag
• Designed for 3S-4S Li-Po batteries
• Can accept motors with 28mm diameter
• Purpose-built for recommended E-flite BL15 Ducted Fan Brushless Motor, 3600Kv (EFLM3015DF)
Delta-V 15 69mm EDF Specifications
• Rotor Diameter: 69mm (2.7 in)
• Shroud Outer Diameter: 73.5mm (2.9 in)
• Shroud Length: 58.3mm (2.3 in)
• Shroud Length (Including Intake Ring): 72mm (2.8 in)
• Center Body Inside Diameter: 28.3mm (1.1 in) – designed for 28mm motor
• Overall Weight: 88g (3.1 oz)
• Delta-V 15 69mm EDF Performance (Data Measured using BL15 DF Brushless Motor)
• Recommended Motor: BL15 Ducted Fan Brushless Motor, 3600Kv (EFLM3015DF)
• Static Thrust: 1.7 lbs on 3S (11.1V) 2.8 lbs on 4S (14.8V)
• RPM: 31,000 on 3S (11.1V) 40,000 on 4S (14.8V)
• Velocity: 71 mph on 3S (11.1V) 102 mph on 4S (14.8V)
• Watts: 305 on 3S (11.1V) 644 on 4S (14.8V)
• Current: 29A on 3S (11.1V) 46A on 4S (14.8V)
ecco il manuale istruzioni della ventola
questo il motore:
BL15 Ducted Fan Motor, 3600Kv by E-flite cod. EFLM3015DF prezzo a pubblico €. 60,00 circa
BL15 DF Motor Features:
• Purpose-built for the Delta-V 15 69mm EDF (EFLDF15)
• Ideal for 68-70mm EDF units requiring a 28mm diameter inrunner motor
• Ideal for up to 750 input watts
• High-quality construction with ball bearings and hardened steel shaft
• 6-pole design
BL15 DF Specifications
• Diameter: 28mm (1.10 in)
• Case Length: 40mm (1.56 in)
• Weight: 106g (3.7 oz)
• Shaft Diameter: 4mm (.16 in)
• EFLM3015DF
• Kv: 3600 (rpms per volt)
• Io: 2.80A @ 10V (no load current)
• Ri: .02 ohms (resistance)
• Continuous Current: 46A*
• Max Burst Current: 55A*
• Cells: 3S-4S Li-Po or 10-14 Ni-MH/Ni-Cd
• Recommended Ducted Fan Unit: Delta-V 15 69mm EDF (EFLDF15)
• Static Thrust: 1.7 lbs on 3S (11.1V) – using recommended Delta-V 15
2.8 lbs on 4S (14.8V) – using recommended Delta-V 15
• RPM: 31,000 on 3S (11.1V) – using recommended Delta-V 15
40,000 on 4S (14.8V) – using recommended Delta-V 15
• Brushless ESC: 50A – 60A
* Maximum Operating Temperature: 220 degrees Fahrenheit
* Adequate cooling is required for all motor operation at maximum current levels.
* Maximum Burst Current duration is 15 seconds. Adequate time between maximum burst intervals is required for proper cooling and to avoid overheating the motor.
* Maximum Burst Current rating is for full high power and limited motor run flights. Lack of proper throttle management may result in damage to the motor since excessive use of burst current may overheat the motor.
ecco il manuale istruzioni del motore
per il regolatore segui quanto consigliato dal produttore
il nostro cliente ha optato per un castle creations ICE 75 che ti da il vantaggio di poterti scaricare il data logging del volo
per la programmazione del regolatore puoi usare questo prodotto
qui le istruzioni della card
buoni voli
rc-modelmania.com non è collegato   Rispondi citando
