Vecchio 09 giugno 10, 21:57   #10 (permalink)  Top
HeliNewbie
L'avatar di HeliNewbie
Data registr.: 23-09-2009
Residenza: Genova
Originalmente inviato da valygar Visualizza messaggio
e pensa tu che verranno controllati tramite tastiera e successiavamente tramite script!oddio che bestemmia cmq in sostanza quante chances abbiamo che montato il tutto l'elicottero con quel peso aggiuntivo si sollevi da terra?che sapendo a priori se avra' problemi uno cerca altre soluzioni
Credo che questo possa esserti di aiuto :
"My answers to the Ever-Popular: How much can my Heli Lift?
I see this on average about twice a month on the various boards, someone is looking at AP and wants to try it with their current Helicopter. People are successfully using everything from small helicopters with 315mm blades to large machines swinging 810mm blades or bigger. Now notice I didn't mention any names there, only blade size. I will be doing this write up based on blade size because that is the determining factor for how much you can lift. This article will be a constant work in progress as I find more information. I will list some helicopters running each size blade so you can easier relate it to your helicopter. The amount you can lift also varies by how much your helicopter weighs without the camera mount and extra gear.
Blade size is in millimeters measured from the end of the blade to the bolt hole.
Keep in mind these are max or near max weights and the helicopter will auto horribly if fully loaded.
Blade Size (mm) - Helicopters - Max SAFE Lifting Capability (g,oz,lb) - Notes
315mm - T-Rex 450 - 450g, 15.87oz, 1lb - keep the total flying weight under 2.2lb
500mm - Logo 10 - 1360g, 48oz, 3lb - keep total flying weight under 9lb
550mm - 30 Size, Century Swift, Logo 14 - 1587g, 56oz, 3.5lb - keep total flying weight under 10lb
600mm - T-Rex 600, 50 size Helicopter, Logo 20/24 - 1815g, 64oz, 4lb -keep total flying under 11 lb
720mm - Gasser, Joker - 6800g, 240oz, 15lb -
800mm - Gasser, Maxi Joker - 9071g, 320oz, 20lb -
810mm - Gasser - 11300g, 400oz, 25lb -
Blade type will play a role here symmetric blades will offer the least lift, semi-symmetric will offer more while flat bottom blades will offer the most lift. However flat bottom will fly bad if there is any wind and semi symmetrical blades will fly worse than fully symmetrical blades in wind. Some people have three sets of blades that they swap out depending on lift needed and weather conditions. I used standard fully symmetrical blades with good results. These will vary dependent on power setup, gear ratio, head speed, helicopter weight, etc but this should give you an idea.
Labels: Gasser, Joker, Logo, logo 20, logo 24, Maxi Joker, raptor 30, raptor 50, swift 10, t-rex
QUI la fonte...
Blade Msr, Blade 4003d, Walkera QRX 350 Pro, Dx8, Phoenix,[COLOR=black] , T-28 Micro,/COLOR]
Parlare è una capacità di tanti; ascoltare è una virtù di pochi; non capire niente è una realtà per molti
Ultima modifica di HeliNewbie : 09 giugno 10 alle ore 22:06
HeliNewbie non è collegato   Rispondi citando
