Ho guardato meglio il manuale....
Dice:
Due to 5A continuous current and 15A peak
current JIVE ESCs allow the use of high
performance digital servos. To provide full BEC
power all JIVE ESCs feature two BEC connectors
which have to be used obligatory at power greater
than 2A. The master connector must be plugged to
the thottle channel. The slave connector can be
plugged in to each unused receiver channel (even
a battery port).
Ma anche, come diceva Silvius nel secondo post:
For safety reasons a four cell NiCd/NiMH
battery must be connected to the receiver
in parallel to the BEC
Aprofitto anche per un altra domanda: che differenza c'è tra modo 4 e 11? Sul manuale non ho capito.
Grazie.
__________________ H 1600 V-Stabi - 12S-5000 - Scorpion HK4525-520 - Jive120HV - 3x8717 - BLS251 H 1400 V-Stabi - 10S 3800 - Scorpion HK4225-610 - Jeve80HV - 3x8717 - BLS251 H 1000 V-Stabi - 6S 3300 - Scorpion HK3026-880 - Jazz80 - 3x9650 - BLS251 |
