Vecchio 28 marzo 10, 23:01   #37 (permalink)  Top
roberto_1974
Data registr.: 06-01-2006
rieccomi qua..
la configurazione è questa, e a seguire il jpg del log
cosa potrei migliorare?
# Castle Link Data File
# Created: domenica 28 marzo 2010
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 39
Direction: Forward (*)
PWM Rate: Outrunner Mode (*)
Current Limiting: Insensitive (175A)
Cutoff Voltage: Auto Li-Po (*)
Motor Timing: 5
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 25
Initial Spool-Up Rate: 2
Head Speed Change Rate: 8
Auto Rotate Enabled: True
Governor Mode Type: Simple
Data Log Enabled: 255
Sample Frequency: 5 Sample / Sec (*)
BEC Voltage: 6
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell
roberto_1974 non è collegato   Rispondi citando
