Vecchio 26 marzo 10, 16:00   #4 (permalink)  Top
luca.masali
L'avatar di luca.masali
Data registr.: 15-11-2005
Immagini: 5
Originalmente inviato da massimob Visualizza messaggio
questa me la incornicio e la metto in bagno
tè, incorniciati pure questa (dal manuale del Triton 2)
A built-in cooling fan helps to keep the charger cool during operation. This will help extend the service life of the charger, and allow it to function more accurately and efficiently. The fan does NOT function at all times. The fan functions (1) during
discharge, (2) during charge, if the temperature inside the charger exceeds 122°F, if the charge output power exceeds 30watts, or the charge current exceeds 2.5A, or if charging batteries which have 1-3 cells, (3) if the internal temperature of the charger exceeds 212°F it will stop all charge or discharge functions until the temperature drops below 158°F – but the fan should continue to run until the temperature drops below 113°F. CAUTION: Do not block the vent holes for the cooling fan. Failure to do so could cause the charger to overheat and possibly cause permanent damage.
www.masali.com
