Discussione: xcelorin 7500kv
Vecchio 19 marzo 10, 20:25   #6 (permalink)  Top
PISTORIUS
L'avatar di PISTORIUS
Data registr.: 11-12-2009
Residenza: FERRARA
One Brand New Team Losi 1/10 Xcelorin 7500kV Brushless Combo Part LOSB9576
Xcelorin- High-Performance Brushlesss Systems
Features:
* Forward/Brake with Reverse or Forward/Brake settings
* Sintered Neodymium rotor
* 100A continuous current with 540A peak
* Losi EC3 power connector pre-wired
* High-speed cooling fan for lower running temperatures and protection
* Low voltage cutoff to protect your investment
* Four LED's to indicate functions
* Two preset drive profiles with unlimited potential with a PC
* Powerful, high-speed brushless motor
* Precision motor ball bearings for smoother operation
* No motor maintenance required
Overview:
Xcelorin brushless systems from Losi represent the latest development in brushless power and performance. The 1/10 Xcelorin Motors and ESCs offer features and specifications desired by the electric RC enthusiasts. With ESC features like, pre-wired high-speed cooling fan, low voltage cutoff protection, multiple programming options and much more. The motor's feature low-profile solder tabs with a protective cover, precision ball bearings for smooth operation, Sintered Neodymium rotors and best of all no motor maintenance is required. For higher speeds and longer run times look to Losi and the Xcelorin brushless systems.
ESC Specs:
Type: Sensorless Brushless
Forward: Y
Reverse: Y
Brake: Y
Time Delay Brake: Y
Throttle Limiting: Y (adjustable in 10% steps)
Programmable: Full (via quick program card or PC)
Continuous Maximum Current: 100A
Momentary Peak Current: 540A
Input Connector Types: Losi EC3 style
Dimensions (WxLxH): 1.16 x 1.54 x 1.3 in (29.5 x 39 x 33.2mm)
Weight: 1.7 oz (48 g)
BEC Voltage: 6.1V, 3A
PWM Frequency: Optimized for Spektrum or Traditional radio systems
Motor Specs:
Bearings or Bushings: Precision ball bearings
Voltage: NiMH 6-12-cells; LiPo 2-3-cell
RPM/Volt (Kv): 7500Kv
Weight: 6.35 oz (180g)
Overall Diameter: 1.4 in (35.8mm)
Shaft Diameter: 0.125 in (3.17mm) with flat
Shaft Length: 0.18 in(4.6mm)
Overall Length: 2.15 in (35.8mm)
This brushless system is brand new in original factory sealed package.
Part LOSB9576
PISTORIUS non รจ collegato   Rispondi citando
