Originalmente inviato da CRO_Fek con la tx di serie non lo cambi quindi e' di fatto fisso  . con una tx programmabile lo puoi tenere fisso o variarlo a tuo piacere. |
Esatto è quello che ho fatto con la DX7:
in normal è addolcito,
in stunt 2 prende anche il passo negativo
questi sono i settaggi di base che ho reperito su RCGROUP, poi li ho variati un poco per i miei pollici:
D/R Expo:
position 0
Aileron - 70% + 35% expo
Elevator - 70% + 35% expo
Rudd - 70% + 35% expo
Add expo as needed for softer feel at center of the stick
Position 1
Aileron - 100% + 25% expo
Elevator - 100% + 25% expo
Rudd - 100% + 25% expo
Travel adjust - all set to 100%
Throttle Curves:
Norm Pos - (for stock SR tx throttle curve)
L - 0%
2 - 45% or 50
3 - 70% or 75
4 - 80% or 85
H - 90% or 95
Stunt Pos 1A (for beginner pitch settings) -
L - 0%
2 - 50%
3 - 70%
4 - 85%
H - 100%
Stunt Pos 1 (for stock SR TX or advanced pitch settings)
L - 100%
2 - 90%
3 - 80%
4 - 90%
H 100%
Pitch Curves:
Norm Stock SR tx settings
L - 55% +1 (can use 50% for zero at bottom stick)
2 - 60% +2
3 - 65% +3
4 - 75% +5
H - 100% +10
Stunt 1A - (Use with stunt throttle settings for beginner -set more like a normal NON SR beginner setup)
L - 40% -2
2 - 45% -1
3 - 50% 0
4 - 75% +5
H - 100% +10
Stunt 1 - Stock SR TX settings
L - 15% -7
2 - 25% -5
3 - 50% 0
4 - 75% +5
H - 100% +10
Stunt 1 Advanced pitch settings (Use with stunt throttle settings for advanced - for those ready for trick flying)
L - 0% -12
2 - 25% -5
3 - 50% 0
4 - 75% +5
H - 100% +12
Note:
Adjust swash mix pitch value to 50-55% to get higher positive/negative throws
Swash Mix :
Aileron +55% If you want less overall movement of the aileron decrease this number....for more increase
Elevator +55% If you want less overall movement of the elevator decrease this number...for more increase
Pitch +35% for higher pitch range increase this number
Under the Setup List:
1) In the reverse menu Reverse the Rudd and Pitch settings
2) Under Swash Type - Select CCPM 120
You can use these setting for the dx7 or the x9303 just be sure your swash is traveling the correct direction.(as always test with your motor unplugged) If it isnt change the - or + values in the swash mix to the opposite (example aileron +55 to a -55)
