Originalmente inviato da campa Many thanks for that excellent ideas
@Marco,
The option "case san Romolo" I guess is near the motocross trac. This would be a verry likely place because it's close to my location (Ferrano). For shure I will check this place.
Why do you think Chiassaia is better than the Pratomagnio? Chiassaia is lower in elevation and verry close to the Pratomagno. More or less the same position. Are there better winds due to the topography?
@Kitaro
I'm "inamorato" into the "prato fiorito".  If I will find the time I will definitely go there to check this place out.
Thanx
Corrado |
Google Translate santo subito
Are two different slopes.
Chiassaia a slope is relatively low, about 800 meters, if the wind blows from the west you can fly in and thermal dynamics in a rather wide range of conditions. The takeoff is easy to land a bit less still feasible even with models from 3 / 4 meters of wingspan, the toll "Valdarno" There are about 40 minutes.
This is a video of the testing done at Chiassaia Antonov A15
YouTube - ANTONOV A 15
Pratomagno is about 1600 meters even better if the wind is south-west to fly only with heat, we define a slope technician, a flight is probably similar to what is on the slopes of northern Italy, are preferable for large models with a thermal power are not uncommon lineages that force to fly away. Takeoff and landing without any problems, the toll "Valdarno" about 90 minutes.
Hello Andrea
