Vecchio 31 dicembre 09, 19:27   #1 (permalink)  Top
Ricky021
L'avatar di Ricky021
Data registr.: 19-04-2005
Residenza: Lainate
Elaborazione con BL Parkzone !
Ciao a tutti !
Devo accoppiare un BL /Esc elica e Lipo al SuKhoi 26m,
voi che siete piu' esperti sicuramente di me nei micro,
sapete dirmi se i componenti che ho scelto sono adeguati ?
Ho gia' provato l'upgrade con elica gws 5x4,3 cambia radicalmente,
ma volevo una marcia in piu' ...
Ho scelto questi :
HobbyKing AP05 3000kv Brushless Micro Motor (5.4g)
High quality micro motors. Precision wound with silver-copper wire and ultra hard-press laminations.
Extreme performance and efficiency for your micro plane.
Factory Spec.
Kv: 3000rpm/v
Lipo Range: 1~2S (3.7~7.4V)
Suggested prop: 5030
Max current: 3A
Burst current (5sec): 4A
Weight: 5.4g (including mount and wire)
Shaft: 1.5mm
Shaft length: 14mm
Dimensions : 14 x 13mm
Test data:
5030 prop (Recommended)
Voltage: 7V
Current: 2.8A
Thrust: 110g
For 70g 3D airplane and 120g normal flying.
HobbyKing XP 3A 1S 0.7g Brushless Speed Controller
The HK 3A is a tiny (around 0.7gram) brushless speed controller built only for single cell applications and for current draw up to a maximum of 4A bursts.
This brushless esc is only to be used for Lipoly single cell applications where no more than 3A constant is needed.
Features.
High speed, Multifunctional MCU.
Full protection features Low voltage, Over-heat, Signal lost failsafe, Safe power On protection.
Smooth startup.
Linear Throttle
Supports 240,000RPM (2 poles) / 40,000RPM(12 poles)
Programable by transmitter
Spec.
Cont. Current: 3A
Burst Current: 4A
Max Voltage: 4.2v
BEC: Not required. power supplied directly from 1S battery.
Programable: Yes
Weight: 0.7g
Dimensions: 11x13x8mm
Note*
Please be careful when using this product. Due to its size and delicate nature it is easy to overload this ESC. Only use single cell Lithium Polymer batteries and never draw more than 3Amps or never more than 4A for more than 10 seconds.
ZIPPY 240mAh 20C single cell
Dimensions: 35x21x5.30mm
Weight : 5.9g
GWS EP Propeller (DD-5030 127x76mm)
Sapete dirmi se puo' andar bene come accoppiata ,peso e tiro?
Grazie mille a tutti voiiii !!!!
Ultima modifica di Ricky021 : 31 dicembre 09 alle ore 19:31
Ricky021 non รจ collegato   Rispondi citando
