Discussione: Saito & cool power
Vecchio 17 novembre 09, 21:43   #4 (permalink)  Top
Renato Privitera
Data registr.: 10-03-2009
Questa e' l'opinione di un americano sulla magica miscela.......(Da RCU Cool Power 5 % glow fuel opinion )
parla di un motore comperato usato, che rivela tracce di esser stato usato con la "roba verde".....
No Cool Power for me thanks... Just dragged this engine out of "The Bay" (so to speak) and it had clearly been run on The Green Stuff. Pulled the backplate and found it dry as a bone and full of rust with green stains. I swished some castor/synth blend Wildcat fuel through it to get a feel for the bearings and compression. The bearings feel OK, but will be replaced, and the compression is most definitely down. You can see how after the alcohol evaporates, the castor oil stays behind.
Besides, Cool Power just plain stinks when running, and leaves an engine, and everything it touches smelling pretty bad as well....
Ultima modifica di Renato Privitera : 05 maggio 11 alle ore 23:48
Renato Privitera non รจ collegato   Rispondi citando
