Vecchio 12 novembre 09, 19:47   #1 (permalink)  Top
Nick Nitro
L'avatar di Nick Nitro
Data registr.: 12-11-2009
Residenza: Venegono Inf - Aosta
Invia un messaggio via MSN a Nick Nitro
Exclamation Consigli su batteria per motore. HELP
salve a tutti, vorrei sapere in linea di massima, per questo motore:
Rotational Speed 2810 RPM/V
Continuous Current 20A
Max. Current 25A
Input Voltage 6 - 22V
Max. Efficiency 98%
No Load Current 0.7A
Internal Resistance 56mΩ
Motor Dimensions (Diameter x Length) 31mm x 26.4mm
Shaft Dimensions (Diameter x Length) 2.82mm x 30.5mm
Input Battery Types NiCd/ Nimh/ Li-po Battery
quale delle seguenti batterie è + indicata??
Dimensions (Length x Width x Height) 105 x 35 x 24mm
4.13 x 1.38 x 0.95 inches
Capacity 2260mAh
Voltage 11.1V
Max Continuous Discharge 25C / 56.5A
Max Burst Discharge 30C / 67.8A
Number of Cells 3
Configuration 3S1P
Battery Connector Type None
Charge Balancer Type 4 Ports Balance
Net Weight 175 grams
Dimensions (Length x Width x Height) 105 x 35 x 22mm
4.13 x 1.38 x 0.87 inches
Capacity 2080mAh
Voltage 11.1V
Max Continuous Discharge 20C / 41.6A
Max Burst Discharge 27C / 56.2A
Number of Cells 3
Configuration 3S1P
Net Weight 160 grams
Dimensions (Length x Width x Height) 146 x 48.5 x 23mm
5.75 x 1.91 x 0.91 inches
Capacity 3800mAh
Voltage 11.1V
Max Continuous Discharge 30C / 114A
Max Burst Discharge 35C / 133A
Number of Cells 3
Configuration 3S1P
Net Weight 308 grams
Nick Nitro non è collegato   Rispondi citando
