| aletronica e motore
Il modello verra' copletato con:
Motore novarossi r57
Marmitta navarossi
Servi mks
Descrizione
Nuovi servocomandi ad alto voltaggio, da alimentare con lipo 2S 7.4V
Operating Voltage: 6.0.V/7.4V
Operating Temperature Range: -10 to +60 Degree C
Operating Speed : (6.0V): 0.041sec / (7.4V):0.033sec
Stall Torque : (6.0V) : 6.85kg-cm / (7.4V) : 8.44kg-cm
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Case: Aluminum-magnesium alloy shell
Connector Wire Length: 15cm
Weight: 2.36 oz. (66g)
Wire Length: 15cm
Dimensions: 40 × 20 × 43 mm
servo del gas, savox 1257
giroscopio spartan,con jr 8900
regolatore elyq
lipo giga power
pale rjx 600
IL MODELLO VERRA' ALIMENTATO TUTTO A 7,4
