Vecchio 27 agosto 09, 22:27   #8 (permalink)  Top
RRRappy50
L'avatar di RRRappy50
Data registr.: 30-05-2006
Residenza: Marte
facciamo prima...
The Srimok 90 represents the pinnacle of Kasama's design and engineering brilliance.
Special Features:
All Metal Srimok Rotor Head - 7075 T6 Hub and Grip Grade, 8mm Spindle
Vibration Isolated 2mm Carbon Fiber Air Frame
High Speed Swash Plate - 120°CCPM, 10mm Main Shaft
CCPM Shaft Drive Cyclic
Titanium Turnbuckle 3mm Control Rod
Three Main Bearing Block, Two Thrust Bearing
Vibration Isolated Clutch Bearing Block Drive
Heavy Duty CAM Clutch One Way Bearing
High Speed Cooling Fan Hub Vibration Isolated
New Look Fuel Tank Vibration Isolated
Rudder Control Rod Linear Bushing Support Vibration Isolated
Carbon Fiber Tail Boom
Geometrically Correct Full Metal Tail System
Tail Aluminum Shaft Drive w/Concentric Joint
Titanium Tail Boom Support Screws
Metal Servo Horns included
Easily adjustable Bevel Input Pinion
Balance, Damper Mount Canopy Vibration Isolated
Fiberglass Pre-painted Canopy
Carbon Fiber Landing Skids
Aluminum Skid Pipe
Futaba T18SZ
Shit-nergy N7
In fase di montaggio...l'incubo ha una sua identità...
RRRappy50 non è collegato   Rispondi citando
