Vecchio 03 gennaio 06, 20:34   #10 (permalink)  Top
giakko
Sospeso
L'avatar di giakko
Data registr.: 26-10-2005
Residenza: BO
Originalmente inviato da davide.pasq
magnum i motori più usati in america ????
ma dove l'hai vista questa?
io ne ho avuto ben 2, purtroppo, uno che a ogni volo non si riesce a carburare e si spegne e l'altro peggio...
Ho appena trovato questo post dove dicono espressamente che al loro campo molti usano motori Magnum e li considerano magnifici ! Bha, non sò che dire.
Yesterday, 07:23 PM Report This Post to a Moderator · #3 mosquitowings vbmenu_register("postmenu_4823463", true);
Registered User
I have two ASP's and two OS's, I like the ASP's better! Especially for the money.
A lot of guys at the field run magnums and they seem to run great. The saito's at the field run good too, but I can't tell any real difference exept the looks and the cost.
Magnum has a lot better local supply line than ASP so I'd recomend them, and that's not probably, but exactly what I'll buy next time I go for an engine.
As I've read in other threads, if you need the most power from your engine, then you need a bigger engine! And for my money, a step up in size with magnum is still about $100.00 cheaper than the smaller saito.
IMHO
Jim
giakko non è collegato   Rispondi citando
