Discussione: Servo per turbina...
Vecchio 22 giugno 09, 11:05   #10 (permalink)  Top
staudacher300
Coordinatore dello staff
L'avatar di staudacher300
Data registr.: 16-02-2004
Residenza: Roma Snakes Hill
ipotizzo, ino-lab della flyghttech :
Mini Servo Digital HG-D251MG per Heli, Ingranaggi Metallo
HG-D251MG DIGITAL SERVO(CORELESS MOTOR)
TECHNICAL DATA
CONTROL SYSTEM: PULSE WIDTH CONTROL
OPERATING VOLTAGE: 4.8V ~ 6.0V
OPERATING TRAVEL: 30°/ ONE SIDE PULSE TRAVELING 370usec
DIRECTION: COUNTERCLOCKWISE/ PULSE TRAVELING 1500 TO 1870
TEST VOLTAGE: AT 4.8V AT 6.0V
OPERATING SPEED: 0.16s/60°(4,8v) 0.13s/60°(6v)
STALL TORQUE: 5.4Kg.cm(4,8v) 6.2Kg.cm(6v)
DYNAMIC TORQUE: 4.8Kg.cm(4,8v) 5.6Kg.cm(6v)
DEAD BAND WIDTH: 2us
FEATURES
AMPLIFIER TYPE: DIGITAL PULSE WIDTH CONTROLLER & FET DRIVER
LONG LIFE POTENTIOMETER: 500,000 cycles
MOTOR TYPE: CORELESS MOTOR
TOP BALL BEARING: MR106 BALL BEARING
GEAR MATERIAL: HEAVY DUTY CARBONITE GEAR & METAL GEARS
HORN GEAR SPLINE: 25 SEGMENTS/ Ø5.96(FUTABA TYPE)
SPLINED HORNS: 4 CLASS
CONNECTOR WIRE LENGTH: 270mm(10.63in)
CONNECTOR WIRE STRAND COUNTER: 0.08mmx30EA
DIMENTIONS
WEIGHT: 21.11g(0.74oz)
http://www.flighttech.it/
