Discussione: ciaoino
Vecchio 20 giugno 09, 02:23   #2 (permalink)  Top
killerstress
Data registr.: 13-05-2009
Residenza: campo
motore trovato
ok credo che questo possa andare bene
motor:
This is the Chameleon 2 Pro Modified Motor from Trinity.
It features a diamond-trued comm, zapped magnets for greater strength, and a dyno tuned brush and spring combination.
FEATURES: 19 turns, 19 Awg. wire.
24 degree fixed timing
Diamond Trued Commutator
Zapped Magnets
Dyno-Tuned Brush & Spring Combination
Removable endbell
Laydown racing brushes
Over-head springs
Dual Ball bearings
Completely rebuildable
Pure copper hardware for lower resistance
INCLUDES: One Chameleon 19 Turn motor.
Three Surface mounted capacitors already installed.
REQUIRES: Motor leads and mounting screws
COMMENTS: The difference between the Chameleon Pro and the Chameleon (TRIC4408) is that the Pro is dyno tuned (and therefore is broken in) and
has better brushes and brush springs.
REPLACEMENT PARTS: Uses Serrated Silver brush. Trinity part #RC4499.
Springs, part #RC4395, Motor Can #4601 TRIC5108.
Meets all ROAR and NORRCA spec for 19-turn motors.
batterie disponibili sono le seguenti: http://i5.ebayimg.com/01/i/001/36/a2/2bbb_1.JPG
adesso mi serve una mano per il regolatore di giri...
ne ho uno a casa http://i.ebayimg.com/21/!BTTyeLwB2k~$(KGrHgoOKk!EjlLm(M-TBKHugdb58Q~~_1.JPG
ltems: 40A
Weight: 28g
Dimensions: 45.0*24.0*9.0mm
Current(A): 30-40
BEC: 3A
PWM: 16K
Li-Po: 2-3
Ni-Mh/Ni-cd: 4-10Ni-Mh
Features:
BEC: 3A
Constant current 30A Max 40A <10s
Li-Poly 2-3 cells; Ni-MH 4-10 cells Auto Detect
Break On/Off;
Auto Low battery Slow down at 3.0V/cell Lipo, cut-off at 2.9V/cell Lipo
elica:
Kyosho stock prop (y431) oppure Performance prop (y531)
http://www.rcsurfrider.com/2002/03/prop.gif
Ho qualche dubbio sul regolatore cosa mi consigliate ?
killerstress non รจ collegato   Rispondi citando
