Discussione: motore 400 DH
Vecchio 23 novembre 05, 09:59   #5 (permalink)  Top
not103
L'avatar di not103
Data registr.: 30-06-2003
Residenza: sondrio
Invia un messaggio via MSN a not103
Io ho trovato una prova dove si parlava di 2600 giri con un 9 denti...
<<Fitting the motor proved to be very straightforward as the motor is tiny in comparison to some of the much bigger motors I'm used to testing. I fitted a 9T pinion which came supplied with the motor. Having set the Phoenix 35 appropriately (fixed throttle, the 400DH does not like governor mode, current limiting disabled.....some explanation of this in the flight testing). I did a test spool up to measure headspeed. The figures returned a willingness to head up beyond 2600 RPM, so I had to use the curves to keep the wood blades within specification of 2400-2500RPM. One of the things I noted during installation was the very thin wires that supply the 400DH with power.>>
Hai provato a diminuire il pignone? Usi il governor?
not103 non รจ collegato   Rispondi citando
