Vecchio 15 aprile 09, 14:38   #1 (permalink)  Top
riktor
L'avatar di riktor
Data registr.: 05-06-2008
Invia un messaggio via MSN a riktor
ho mandato la segnalazione a giatcod e mi ha mandato una lettera che mi dice di spedire la ricevente ad un tizio in uk che farà un controllo indipendente ecc ecc
i spiegate di preciso cosa devo fare, come deve essere la spedizione e che ci devi scrivere dentro che con l' inglese non è il mio forte! allego la mail:
Hi Lorenzo,
Can you return it to:
Returns
John ********
West Midlands, United Kingdom
John is an independent, holds no stock and gives an unbiased opinion. His decision is final and we have no say on it. We ask you to respect it. It is pointless sending something to him if you don't.
Please not that we will not accept any items that have been damaged, dismantled or modified in any way by the end user, this includes soldering / gluing etc, leads cut or shortened, connectors exchanged. We obviously cannot accept items that have been opened as we can't return them back to our suppliers. All RC suppliers have this policy, not just us. All batteries are checked for being shorted and balanced cells before going out.
If any product is returned to us and found not to be defective or has been damaged as a direct result of misuse a surcharge will be incurred, as will returned postage. Goods found not to be faulty will not be returned to the customer until we receive the surcharge payment of 30% of the cost of the item. We have to pay to get the goods checked.
Put a cover note in there, explaining. No inspection of goods will be made if sender fails to provide full details and fault description.
PLEASE MAKE SURE NAME, TICKET NUMBER DESCRIPTION OF FAULT SETUP AND ANY OTHER RELEVANT DETAILS ARE INCLUDED. No inspection of goods will be made if sender fails to provide full details and fault description.
If requested we will put the results along with all email correspondence on the Giantcod forum to ensure transparency which should ensure you are treated fairly.
It will be checked and if found to be at fault it will be refunded.
Regards,
Rob
www.giantcod.co.uk
Ticket Details
Perché i sogni... è bello costruirseli con le proprie mani... non ARF!
In Cina, il problema è sempre in Cina
riktor non è collegato   Rispondi citando
