Vecchio 17 febbraio 09, 21:55   #1 (permalink)  Top
organiza
Data registr.: 17-02-2009
Smile Oscillatore sinusoidale a frequenza variabile con la valvola JAN-CG-2C43
Qualcuno saprebbe suggerirmi un circuito elettronico per un oscillatore sinusoidale a frequenza variabile da…(meno possibile 100Hz? 1KHz? a circa 3GHz)con la valvola JAN-CG-2C43?
E' un vecchissimo triodo in vetro in versione coassiale (a faro) e zoccolo octal, con cui si facevano oscillatori in linea risonanti un quarto d'onda. FIno al gigahertz, a spanna fra le due guerre e dopo la seconda guerra mondiale.
indirizzo: organiza2@libero.it
DATASHEET
NJ7P Tube Database Search
2C43
Planar Triode
Base & Bulb ( GE1 & TT-5)
Application
The 2C43 is a triode of lighthouse construction designed for use as a Class C radio-frequency amplifier or pulsed oscillator at frequencies as high as 3370 MHz.The radio-frequency cathode connection is made through a disk-type capacitor which is incorporated in the tube. This results in a low-impedance radio-frequency path from the cathode to the external circuit.The envelope construction results in low losses, provides convenient electrode contact surfaces, and enables the tube to fit easily into coaxial circuits. Requires an octal socket.
Mechanical Data
Bulb .......................................... Special
Base .......................................... Glass & Metal
Maximum Overall Length ...................... 2.688 In.
Maximum Diameter ............................ 1.312 In.
EIA Base ...................................... 2C40
Cathode ....................................... Coated Unipotential
Electrical Data
Heater Voltage ................................ 6.3 V
Heater Current ................................ 0.9 A
Direct Interelectrode Capacitances (approx)
Triode
Input ......................................... 3.0 pf
Output ........................................ 0.04 pf
Grid to Plate ................................. 1.8 pf
Maximum Ratings (Design Center Values)
Triode
Plate Voltage ................................. 500 V
Plate Dissipation ............................. 12 W
Characteristics and Typical Operation
Class C Oscillator/Amplifier
Plate Voltage ................................. 470 V
Grid No. 1 Voltage ............................ 100* V
Plate Current ................................. 38 mA
Power Output (approx) ......................... 9 W
Class C Oscillator/Amplifier (3370 MHz)
Plate Voltage ................................. 3000 V
Plate Current ................................. 2500 mA
Power Output (approx) ......................... 1750 W
Ultima modifica di organiza : 17 febbraio 09 alle ore 21:57 Motivo: dimenticanza
organiza non è collegato   Rispondi citando
