Discussione: Tangent Alpina 5001
Vecchio 12 febbraio 09, 11:20   #6 (permalink)  Top
batman
Sospeso
L'avatar di batman
Data registr.: 21-01-2005
Residenza: La Civile e Ospitale Emilia
Originalmente inviato da trasciatti123 Visualizza messaggio
Tutti i modelli della tangent sono tutti rinforsati o addirittura tutti interamente in carbonio. Quindi per resistente intendo con ali e fuso adatte a forti venti in pendio ma nn da appesantirle eccessivamente per il volo in pianura. Un pò contorto ma il succo è questo....
subject to ongoing development and testing by a team of highly competent model pilots.
Homepage - Sitemap - Disclaimer - Contact
Tangent Contestline
Tangent carbon constructions
Kult Mini
Kult Mini-Duo
Alpina 2501 NEW
ASW 27 B
Pilatus B4
Flamingo 2006
ASG 29
Kult
Kult elektro
DG 600 EVO
Euro Master
Elektro Master
ASH 26/ASH 26-E NEW
Alpina 4001 Pro
Alpina 4001 elektro
Alpina 5001 Pro/elektro
Vortex/Vortex XXL
Vortex Champ
Mistral 4.7/4.7-Comfort
Nimbus 4 Dealers
EDITIONS
1. Carbon Thermic-Edition
Carbon Thermic Edition – for general sport flying, these models achieve an excellent balance between rigidity and weight. The main spars are reinforced with graduated Carbon fabric, both top and bottom, all the way from root to tip.
2. Carbon Master-Edition
Carbon Master Edition – for more demanding model pilot, and for larger models involving higher flight loads. In addition to the Carbon reinforced main spar, the D-box is also clad in Carbon fabric, which is laid down at +/- 45° angles for optimum performance in both tension and compression. The Carbon reinforced D-box extends from the leading edge and embraces the main-spar.
3. Full Carbon Tec Edition
the no compromise solution, when only the best is good enough! In addition to the Carbon reinforced main spar, the entire wing area is reinforced with Carbon fabric, which is laid down at +/- 45° angles for optimum performance in both tension and compression.
L' Alpina è "Carbon Master", quindi una via di mezzo (per le ali, naturalmente),
La fuso di solito è in VTR con rinforzi in carbonio
batman non è collegato   Rispondi citando
