| Le riceventi 2.4GHz...
We are launching a range of 2.4Gig recievers in 7, 9 and 16 channel versions. RX-7-DR light M-LINK 2.4 GHz receiver # 5 5810
This is a small, all-purpose seven-channel receiver exploiting MULTIPLEX 2.4 GHz M-LINK technology. It is a dual receiver, featuring two complete receiving circuits operating in parallel (receiver diversity), ensuring excellent reception quality in spite of the units small dimensions.
The RX-7-DR light M-LINK is a particularly good choice for the smaller model as it is so light and compact. The in-line connector arrangement and compact case design make it suitable for installation in slim glider fuselages, e.g. F3B, F3J,
HOLD / FAIL-SAFE function
Integral button and LED for Binding, FAIL-SAFE programming, RESET and operating status information Specification:
Servo channel count 7
Reception system 2.4 GHz FHSS
(Frequency Hopping Spread Spectrum)
Operating voltage 3.5 V
9.0 V
Power supply 4 - 5 NiXX cells, 2S LiPo / LiIo
Permissible operating temperature range - 20°C
+ 55°C
Dimensions (L x W x H) approx. 38 x 28 x 11,5 mm
Weight approx. 10 g
Due June/July RX-7-DR M-LINK # 5 5811
RX-9-DR M-LINK # 5 5812
High-quality seven-channel / nine-channel receivers exploiting MULTIPLEX 2.4 GHz M-LINK technology. These receivers utilise the latest SMT construction, and are suitable for all types of model.
Their compact dimensions and in-line connector arrangement allow them to fit even in models with limited internal space. These receivers feature two complete receiving circuits operating in parallel (receiver diversity). In conjunction with a special signal amplification circuit this ensures very high sensitivity, excellent reception quality and maximum effective system range.
Telemetry / Feedback channel capability
Integral sensor interface for connecting external sensor modules
Prepared for dual-receiver diversity operation (diversity lead # 8 5070 required)
Integral error counter / data logger (voltage errors, signal errors)
MULTImate compatible
Integral PC interface Specification:
Servo channel count 7 / 9
9.0 V
+ 55°C
Dimensions (L x W x H) approx. 55 x 35 x 11,5 mm
Weight approx. 25 g
Due June/July RX-9-DR pro M-LINK # 5 5813
RX-12-DR pro M-LINK # 5 5814
RX-16-DR pro M-LINK # 5 5815
Our premium range of M-LINK receivers: 9-channel, 12-channel and 16-channel MULTIPLEX 2.4 GHz units for the demanding modeller. These receivers feature two complete receiving circuits operating in parallel (receiver diversity). In conjunction with a special signal amplification circuit this ensures very high sensitivity, excellent reception quality and maximum effective system range.
All three receivers feature replaceable aerials; fitting aerials of different length enables the user to deploy the aerials efficiently in any model. The aerial connectors are fitted with high-quality gold-plated contacts.
The receivers also feature a MULTIPLEX M6 high-current connector which provides a reliable connection for the receiver power supply; an external high-power supply unit is not required. Another interesting feature is individual protection for each servo socket against overload and short-circuit; this ensures that the power supply to the rest of the system is not adversely affected if a fault occurs in one component, such as a defective servo.
Yet another special feature is the cable securing clip. This can be fitted to the case when required, and protects all cables from working loose accidentally. Highly recommended for models where vibration is a serious problem!
Voltage errors and signal errors indicated by separate LEDs
Servo channel count 9 / 12 / 16
9.0 V
Permissible operating voltage range - 20°C
+ 55°C
Dimensions (L x W x H) approx. 86 x 54 x 18,5 mm
Weight approx. 60 g
